Jamo MPA201 2-Channel Amplifier Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power led on but no output - Jamo MPA201 2-Channel Amplifier
Anonymous
Level 2:
Sergeant:
  • Expert 298 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
298
Questions
Helped
115291
Points
566
Try to trace the fault systematically from one end of the system to another, starting with something that you know is working
  1. Start by checking your sound source (cd player or whatever) is working by connecting it to another amplifier or computer.
  2. Check the connecting cable is working from the sound source to the amp and is not shorted out.
  3. Make sure your loud speakers actually work (briefly shorting a 1.5 volt AAA battery across the speaker terminals should produce a crackling sound without doing any damage)
  4. Check loudspeaker cables are properly connected to output connectors and are making a good contact.
  5. Try connecting something like your computer speakers (or use the microphone in jack on the computer itself) to the line output socket of the Jamo. If you can get some sound this way it would suggest that the internal output overload protection fuse may have blown. You will need to open the case to access this. NOTE if your JAMO is still in warranty take to authorised repairer otherwise you may invalidate your warranty.
1helpful
My Sony LED tv is not turning on (due to) output lower voltage level
Replace the power adaptor with one providing the correct voltage. Many modern devices will not even try to turn on if the provided power is insufficient. Because that can ruin the delicate circuits inside.
LG LED tv backlights not coming on. Replaced power supply board and LED strips, did not fix. Should I move to replacing main board? Model # 42LN5300
Wow, a master replied, if you need to buy TV accessories, you can take a look at this website:www.abctay.com
1helpful
I have an LG 42 TV that powers up and only shows black screen.
Chances are you have some open LED's, if one opens the entire strip will go out as they are wired in series and the power supply is shutting down the LED circuitry due to improper current or voltage
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
How do I take a picture?
use complete sentences please when asking a question in the form of a category
I have outdoor led christmas lights controlled by your #0154182 timer. Voltage must be getting by because a faint glow can be seen when the timer is off. Talked to Lowe's and they have never heard of this....
the timer has what is called a solid state output and since Led's draw much less power the solid state output can not correctly shut off all the power to the lights (design flaw) i suggest adding just a few of the old incandesent lamps to the same output this should signal the solid state output to turn all the power off correctly
Dec 07, 2013 • Garden
2helpful
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
3helpful
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
