Hasbro Idog Pink Logo
Posted on Jul 27, 2008
Help hello i was wondering if you could tell me where i can find instructions for putting a little boys car set track together. it's called speed legends
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Jul 31, 2008
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
33869
Points
70
Well you have to slide the cars on to a track piece in the right direction then configure the pieces in any way you want and then the battery motors should send the car down the track
1helpful
I need instructions for putting the train and track together
hi Joyce.
is this a electric train set or a battery set?
could you please give me more info on this please.
can you please tell me what train set this is.
or go to this link might help you out on how to put a train set together.
how to put train track together Google Search
Dec 01, 2017 • The Toys
Please tell me how to change the time on my cordless Panasonic cordless phone , Model # KX-TG6531, do not tell me to look at the manual, I read and still do not understand how to set it so it does not...
Hello, Maureen.
According to the instructions, you set the date and time together. I'm wondering if neither work for you or if only one works.
As you are aware set the date and time;
Press the MENU button then # 1 0 1
Select the month, day and year. For today: 110711
Select the OK button
Enter the current hour and minute: 0730 (for 7:30)
For 7:30 PM, select the PM button
Select the SAVE button and then the OFF button
Hope this helps.
Nov 07, 2011 • Cell Phones
2helpful
I am not able to put this train set together some tracks have letters others numbers
the tracks with letters are misty island put c and d together for corners (swap other side) then rickty bridge inbetween on one side and switch track on other. For numbers pretty much you can go by number (start with 1 and go left) I had to fidget a little but it worked
1helpful
2answers
Instructions for the New bright 384 holiday express
Not sure what instructions you need, but the setup is very simple.
1. Put your track together
2. Attach the track power connector by slipping it under the track and pushing, then lift up the other side. This will make the two metal contacts connect to the track.
3. Plug the connector from the power pack into the track module (It should only go one way)
4. Plug the control box (looks like a telephone cord) into the track module, Will only go one way
5. Place the locomotive on the track.
6. Place the Treetop Tender on the track (you need both to make it run)
7. Connect the large connector from the treetop tender to the loco
8. Turn on the command module and press forward ...
You should now be running in circles ...
Hope this helps...
Cars Toddler Bed problem
mcdevito75 here, Use the contact info in the istruction manual you have, and speak with Disney.
4helpful
2answers
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Where can I get the instruction manual for the Artin Giant loop Express?
Hello my name is Miguel Angel, I'm from Mexico and I have that highway. I could send you the manual, just send me an email: [email protected]
Mar 19, 2009 • Toys
2003 dodge stratus multiple misfire
you hooked the wires up wrong the whole fuel injector wire assembly goes up to the fire wall then clips into main wires
the fuel injector track is one track with wires
when you replace wires you also want to replace the injectors to match
buy new engine wire harness this will solve the problem
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
