Remove and clean the water level sensor and see if this resolves your error. If cleaning doesn't do it, check the connector for buildup. If neither of the above works, you'll need to order a new sensor - I've gone through two in four years as the heat appears to crack the plastic housing, allowing water to wick up between the plastic and the contact, ultimately shorting it.
