My Zenith Inteq IQB55M90W is not turning on at all even though it is plugged in. I know the outlet works, it just wont turn on. What can I do to fix it?
Look for any loose contacts in the power outlet. Switch off TV manually at the TV side, switch off power and remove plug. Retry after 48 hours. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Power supply...The vacuum sound you heard was a capacitor failing. A capacitor stores energy for later use. For example, you turn on your TV, seconds later you hear a "Woosh" and the picture comes up. This is your tv's capacitor discharging. It's a simple fix if you know electronics though I wouldnt recommend repairing this yourself. There are several capacitors inside your TV. Though not fatal, they can give you a jolt. Call a repair man. I hope this helps : )
If you are certain you have power at the outlet, try plugging a lamp into the outlet and see if it lights up, then you may have burned out power supply
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
LG`s home page doesn`t show an e-mail address but heres the next best thing. 1-800-243-0000 be sure to have your model number ready when they answer, hope they still have one
I would check with LG/Zenith on this, there was a update sent out to add a collection cup in case this would happen. If leaked on the board it would be to costly on repair with the board is still available.
