Newer Chevy vehicles without the EVIC buttons normally go out with a sequence of turning the key from off to run (without starting) 3 times and flooring the accelerator pedal 3 times. Once you start it it should go out. If it has a % oil life left screen in the EVIC press the trip reset button until the oil life screen appears and then hold the button until it reads 100% oil life.
Turn the key to the on position. Not the start. And press the gas pedal all the way to the floor 3 times.
Hello: To reset the oil life: Turn key on (engine off) press accelerator pedal ALL the way to floor (no mats under the pedal) three (3) times within five (5) seconds.
SOURCE: How do I reset the
Is there a reset button where I can turn off the Check engine light on a 98 Corolla? There has to be somewhere. After certain miles it will come on and I know from another car I had that it won't cut off until it reaches a certain amout of mile but someone told me where the reset buton was and I didn't have to deal with that annoying light anymore.
SOURCE: HOW DO I RESET THE CHANGE OIL LIGHT ONCE THE OIL
look in the manual......turn the ignition to the on position not starting it of course and then pump the gas petal 5 times then the light will blink a few times turn off then back on...problem solved
SOURCE: reset engine oil change light
turn the ignition on and press the gas pedel three time and the oil light will blink and the go off the then the system will be reset
