Sony Ericsson XPERIA X10 Cell Phone Logo
A
Anonymous Posted on Feb 14, 2018
Hello there. So my Sony Xperia x10 keeps turning itself off. Like whenever I use it, it just shuts itself off and then turns back on. It repeats that process for like 3 times, then it finally boots up correctly. It doesn't matter for how long I use it. Any solution to this problem? Thanks!
Lawrence Oravetz
Level 3:
  • Sony Ericsson Master 10,558 Answers
  • Posted on Feb 14, 2018
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2700505
Points
29284
Check the battery to see if the sides are bulging in the middle. Do a spin test. Take the battery and put it on a flat surface, then spin it like a top. If it spins at all, the sides are not flat and the contacts are moving away from the contacts in the phone.
5 Related Answers
Anonymous
  • 1382 Answers
  • Posted on Jun 25, 2010
SOURCE: sony ericsson xperia x10 unlock code
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
Anonymous
  • 179 Answers
  • Posted on Jul 13, 2010
SOURCE: How to set MP3 as text message tone on Sony
If you want to set an mp3 or "Custom" tone for your "Notifications" you can dowload an app or...
Connect your X10 to your computer. Pull down the usb notification in top left of screen and mount sd card.
Then go into your phone menu via "My Computer" and either go into media/audio/notifications or create the folders yourself. Remember they must be lower case letters.
Then all you have to do is copy your tone into the "notifications" folder disconnect your phone from your pc and go into "Settings" "Sound and Display" "Notification ringtone" and it should now be in your list with the preset standard tones.
Anonymous
  • 179 Answers
  • Posted on Jul 19, 2010
SOURCE: Sony Xperia X10 Unlock Attempt Left
No way of finding out how many times the wrong code has been entered but...
You can still unlock the phone by using
"totalgsm"
software and your data cable that you got with your handset.
You will need to pay for some credits for the software to unlock your phone and your computer needs to be connected to the internet whilst it does it.
It's worth looking around for different prices too. I looked for a c902 and found prices ranging from £25 to £7 after you work out the exchange rate from Dollars to Sterling.
$40 is the starting price see how low you can find it. :)
Anonymous
  • Posted on Aug 14, 2010
SOURCE: My Xperia X10 always restart and can't run and open again.
i don't thrust your name you thief:D
no i don't know.. i'm sorry
Anonymous
  • 5 Answers
  • Posted on Sep 08, 2010
SOURCE: ive locked the xperia x10 by doing the wrong locki...
well...
If you dont have it, try to sing up for a gmail or google account from other computer, and when you have it your mail accout, you must type it at Xperia........
If not, you must go to a dealer shop, to fix that problem.
PHONE SHUTS DOWN UNEXPECTEDLY
To me - it sounds like a battery fault.
Symptoms of a failing battery:
* Device suddenly shuts off, even when the battery have several percent remaining.
* Device drains fast, even when not used.
* Device might just shut off for no whatsoever reason when doing something that draws a lot of power, and will restart just fine.
* Device has a surprisingly fast charge time from empty to full.
If you said yes to those, grab a new battery.
But beware:
There are many fake batteries out on the market, claiming that they have higher capacity, yet very slim in size.
There's a simple rule when it comes to battery capacity:
More capacity = larger in size, which might need a special back-cover. There's no escape from that.
If one would happen to find a such incredible slim battery with super capacity, the battery security circuits and/or chemical makeup probably have been circumvented/changed, and have a high risk of catching fire and/or explode when charging/discharging.
2helpful
My phone tends to shut down on its own whenever it wishes and turns back on at random. what might be the cause, can you help?
try this hard reset method
Resetting the phone
Resetting the phone deletes all data, including downloaded applications, and resets the
phone back to its initial state, the state before you turned on the phone for the first time.
Make sure to back up important data you have on the phone before you reset the phone.
To reset the phone
1 From the Home screen, drag upwards.
2 Find and tap Settings > SD card, USB Mass Storage & phone storage > Factory
data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
There is also a RESET button on the back side of the device (under the IMEI sticker in the lower left corner) under the battery cover.
Charging prblem sony ericson xperia x10 red light blinking then stop
do you know anyone that uses a Sony Erricson Xperia X10 phone? If yes, borrow the battery and test it with your phone. If your phone turns on with the borrowed battery, then this confirms that it's a charging problem.
Read my tip on the below link, to diagnose and solve the problem.
Click here: http://www1.fixya.com/support/r8742993-phone_charge
If the contents in the above link doesn't help, please let me know for further assistance.
Regards.
Walesarumi
Sony ericsson xperia x10 charging problem
Regards.
Walesarumi
2helpful
2helpful
My phone keeps shutting off randomly whenever I'm talking on it or even trying to use the internet. It's always at night around 9 or 10.
Try updating the software on your phone... Directions for this can be found on the sony ericsson main website..
Sony ericsson phones usually start giving problems after some use, and replacing the software usually takes care of the problem..
regards
3helpful
I need to hard reset my sony ericsson X10 forgot user name email and password for to many patterns attempted
Try this method below on how to hard reset Sony Ericsson Xperia X10:
1. Turn the power off first. If the Sony Ericsson Xperia X10 is frozen, take the battery out from the device and then reinsert it back again after a few seconds.
2. Hold the Left and Right Keys located beneath the LCD Display
3. Press and release the Power Key
4. Just then follow the on-screen instructions that appears to hard reset the Sony EricssonXperia X10
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
