when mode you selected will be operational the blue light will blink.every time before the cycle begins the blue light will blink with the slight delay of 10-30 sec.
ok if its blinking orange then there's a problem most probably with the wireless. have you tried to desactivate your wireless and then reactivate it again!! or what you can do change the security type and see what it does!!
Type
192.168.2.1 in your internet browser, and mess around with the settings. like the firewall on the ps3. You can find the ps3 IP under system information. The router more then likely named your ps3 by its ip. then look up a video on how to port forward your ps3 with your router.
u have a computer controlled sensor working or reading out of normal range, need to go get a computer scan of failure codes, make sure u write them down if any transmission codes r present repair first engine codes then trans. codes
Use the orange tool to remove the blade. IF you don't have the tool,
just find a big wire around 1/8 diameter thick . Bend it and insert both ends
on the blade holes. Cover the sharp blade with cloth or use leather
gloves. Turn and remove the blade. The orange filters removes easy.
No, green light flashing when hard drive is working.
Orange light is when your pc not have power on or not have enough power on.
Try to connect to other adapter and see if kind a difference.
mine is blinking green but wont print
The orange light is blinking & I cant figure out what to do.
