Cell Phones Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whenever i try to send a text message, a box pops up saying " Network Service Unavailable" but i can still call people with no problem ??
Anonymous
Level 3:
President:
  • Master 1,469 Answers
  • Posted on Feb 14, 2011
Anonymous
Master
Level 3:
President:
Answers
1469
Questions
0
Helped
354878
Points
4619
Hi,the message that pops up saying "Network Service Unavailable" might be from the message settings not correctly set and it is unable to send messages.
You can go to the message setting options on the cell phone to confirm if it is rightly set.
To be sure, you can also use the sim card on another phone to confirm, by using the a friends phone to send a message.
If the message settings are correctly placed, the problem might be from the sim card. You willneed to contact Sim service center for help to rectify the problem for the Sim card..
Take care...
1helpful
Cant send message on my samsung S3353 but i can call, received text and call..
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
1helpful
2answers
My phone says limited service and i can't send text or calls.every time i send message it says unavailable service. When i try to call it says emergency call only... What should i do.. any suggestion...
THAT MAYBE BECAUSE 1. EITHER NETWORK IS UNAVAILABLE 2.MOISTURE IN SIM-SO TRY REMOVING AND REINSERTING THE SIM 3.UR SIM IS LOCKED DO VOTE FOR ME IF IT WORKS.BEST OF LUCK.
1helpful
I just bought a Corby mate (b3313) and using a Vodafone connection . I installed the required GPRS settings but however it's not working..Every time i try opening the browser(NetFront Browser v3.4),...
Call your SERVICE PROVIDER
Ask them send you the GPRS settings again....Then when you receive them (you will receive them as text message) save them and run as defualt if you been asked...Then turn your mobile off for 3 minutes
Then turn it on ...it will work 100%
May 19, 2011 • Cell Phones
I cant seem to connect internet to my samsung corby phone . everytime i try to access the internet , the internet stops , and a message pop out saying , " service unavailable " i want to connect...
hello,
contact your network provider and ask them to send the internet setting for your mobile.they will send you.save those settings.after saving restart your phone and activate your internet now.
try to access the internet in your phone now.if still having the same problem then there must be problem in your mobile.try to format the phone.try to access the internet after re installing. this will definitely works. if still having the problem then you can contact your service dealer for this problem.
thank you
12helpful
5answers
Samsung Impact pnone. Cannot send a text message. When I try,an error comes up saying "network settings unavailable". Incoming and outgoing calls work, as well as incoming texts. In the messaging menu the...
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
good luck
1helpful
Network settings
I have this problem on Telstra when I restart the F480T.
To fix in Australia on Telstra:
- Widget->Messages
- Settings->Text messages
- Text message centre settings
- Edit Text message centre 1
- Centre address = +6141706700
Save.
You can get the centre address from anybody on the same network as you.
7helpful
Help with my sync "network settings unavailable"
like i said in the above post, go into text messaging center and change the setting from empty to SMS
Can't text with this cingular razr with a tmobile sim card
Your service center number may be wrong in the phone. Call T-Mobile and ask for the service center number. You should be able to find it in your text messaghing settings. If it is rong (since it varies between carriers) it will stop text messages from going out.
You may also want to try your sim in a tmobbile phone and see if you can send text. Might be a problem on the network, not just with your cingular phone.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
