Sony UP 895 Thermal Photo Printer Logo
Posted on Feb 11, 2011
The printer will form feed, but when you try to print to it from the display or from ultrasound unit all it does is beep. I think it may be the main bd. what do you think?
Anonymous
Level 1:
  • Contributor 52 Answers
  • Posted on Nov 08, 2011
Anonymous
Contributor
Level 1:
Answers
52
Questions
0
Helped
23577
Points
84
If all you hear is just a beep when you send the print command, the print signal is working, there is simply no video present on the printer side.
Check the video cable or replace it if needed. Also, check video output settings of the ultrasound system. Sometimes, the S-VHS or Y/C is selected and won't generate a CVBS signal (composite video signal) and that is what you need for the printer. Please select composite video instead of S-VHS in that case.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
136
Points
This sounds mostly to be the remote jack is broken or the pins on the jack need to be resoldered.
1helpful
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
1helpful
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
2helpful
Printing not clear (its so Blur)
Perform these operations:
  • Test->Diag->Clear->NVRAM
  • Test->Diag->Clear->CalData
  • Then re-calibrate the printer.
Procedures:
  1. Turn ON the Tech Access feature (hold ENTER and LINE FEED keys depressed approx. 5 seconds - until printer "beeps")
  2. Turn ON the Fault Override feature (hold ENTER and FORM FEED keys depressed approx. 5 seconds - until printer "beeps")
  3. Press the MENU key then UP Arrow to Offline - Test Menu
  4. Press ENTER then UP Arrow to Test Menu - Diag
  5. Press ENTER then UP Arrow to Diag - Calibrations
  6. Press ENTER then UP Arrow to Calibrations - Print Engine Cal
  7. Press ENTER and follow the instructions on the display
  8. Turn OFF the Fault Override feature by holding the ENTER and FORM FEED keys depressed until the printer "beeps"
  9. Turn OFF the Tech Access feature by holding the ENTER and LINE FEED keys depressed until the printer "beeps"
Printing multi copy forms
you can check your paper size or the tear of poit and set it to that point.
2answers
No puedo configurar el top form de la impresora
aprendizaje hablar español :)
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
No he intentado traducir las instrucciones mientras que puede causar la confusión.
1helpful
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
Keep me posted if you have inquiries, thanks!
Printer is not aligning paper properly.
Please try the following to resolved that issue:
2helpful
2answers
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
