You hook the wii up as normal. The wii needs to be able to connect to the internet. On bootup go to the wii shop, channels and download Netflix or Hulu Plus. (Sign up for those services seperately)
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
1: Make sure you have the volume on the TV turned up and the audio-video connections plugged into the same-colour plugs. Sound only kicks-in once you are at the Wii menu. If this doesn't work, continue to step 2.
2. Test the Wii with another TV. If you have sound there, then it is possible that the HDTV's sound inputs plugs are damaged. Send your HDTV off for repairs.
3. If the Wii does not work with the other TV, then it is likely that the audio cables are damaged. Order a replacement from Nintendo (instructions are in the Wii user's guide)
try unplugging the console the power button never turn off ever anyways check the connection and try a differnet tv and if all else fails call nintendo they should have a fix
