D-Link DP 301P (DP-301P) Print Server Logo
Posted on Feb 09, 2011
I have print server DP-301U Pls let me know the default IP address for configuration
Nicho Liebenberg
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Feb 09, 2011
Nicho Liebenberg
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
3693
Points
61
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Ip address di default del dp-301u
This is a wrong problem solver, because 90% of this site contains SPAM instead solution, confusing user totally. Please remove the SPAM from site or remove this site from the Internet. Thank you.
3helpful
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
4helpful
What is the ip?
default IP address of DP-301U is 192.168.0.10
3helpful
Browser Setup Access address for DLink DP-301U Print Server
It's in the quick installation guide, which is freely downloadable from their web site. Top of page #3...
"The factory default IP address of the DP-301U is 192.168.0.10."
2helpful
2answers
Setting up IP address on server
Download and install <a href="http://www.wireshark.org/download.html">Wireshark</a>.
After installing, click the first button on the toolbar to list available capture devices. Select the interface you use to connect to your network (wired or wireless card) by clicking the "Start" button next to it.
Power off and back on the print server. Watch the log on Wireshark, and look for the D-Link identifier under the "Source" tab. In the same row, it will tell you the IP address the print server has assigned to it. You can then change your computer's IP to be in the same subnet (match the xxx's in the address xxx.xxx.xxx.yyy), allowing you to connect to it.
3answers
D-Link DP-301U Problem
It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
Is this the wireless print server?
What specifically do you mean by PJL printer block?
DP 301U and Lexmark 2550 (all-in-one)
1. Set up your print server with an IP address.
2. Ping your printer IP address.
3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
5. Print.
Hope this helps.
1helpful
D-LINK DP301U
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
2answers
Unknown address
Install Network Manager in your and install . When you install this software then you go to networkingmap there you will get ipaddress of your print server
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
