1998 Volkswagen Beetle Logo
Anonymous Posted on Feb 06, 2011
Remote won't work, can't start car (alarm system goes off) Also, key won't turn manually in door. FYI` car battery replaced a few months ago. Also tried replacing batteries in remote. When I parked the car recently, shut it off, removed key the door didn't automatically unlock as they are supposed to.
Anonymous
Level 2:
Scholar:
  • Expert 76 Answers
  • Posted on Feb 06, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
76
Questions
Helped
32086
Points
197
Open the trunk with the key, it will disable the alarm. You probably need a new door lock cylinder, which you should look into. They're easy to replace, but take a while to get, as they have to be coded for your key. You can also remove the door lock cylinder by loosening the t20 torx screw near the door handle until the lock cylinder slides out(DO NOT LOOSEN MORE THAN NECESSARY TO GET THE LOCK CYLINDER OUT), then use a flathead screwdriver through the hole to activate the lock.
  • Anonymous Feb 06, 2011
    Forgot to mention that if you are going to take the lock cylinder out you need to pull and hold the door handle at the same time. Once the lock cyl is out, hold the handle out and retighten the torx screw so that the door handle works.
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Mar 14, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
714
Points
My 2001 beetle wont run it starts but it wont idle or run
1helpful
2answers
I have a 2005 colbalt ..i dont hv the remote key..everytime i open the door with key or not alarm goes off..first like a horn sound then louder it goes off and sometimes not untill u turn key on
thats how its suppose to work the key resets alarm ==by a fob online for a few dollars and program to car [free program] ==when you use key to unlock and enter vehicle you have a few seconds after opening door to turn vehicle on or start it and doing so resets alarm when you leave vehicle and lock it alarm is active
Turn off security alarm
Have you checked the battery in the remote ? Sounds like the remote is not functioning.
Trailblazer won't start
Open the door,when alarm goes off insert key into ignition and alarm should go off and it should start,try that.
Alarm won't turn off
Turn key to on position, but not start it. Push red button on left of steering wheel twice, then start
6helpful
2answers
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
1helpful
2answers
Pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
