Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Just turn On the computer and then press and hold "0". holding the power button will cause the computer to turned off. Turn off the machine then turn it back on then press "0".
Thanks for using Fixya
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard
drive utility screen. The key command differs depending on the model
Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in
System Recovery. Verify that you want to continue the process by
clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been
completed. You will be prompted to enter information such as the date,
time and language preferences.
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PC(laptop and desktop).
Don't hold the power button when you start the PC, hold the zero (0) and tap the power button once, while continuing to hold the number 0 key down until you here the pc beeping
1) completely turn off your machine.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping, then you can release the 0 key.
4) from the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. click next.
7) Next to Start recovery.
let me know if this helps you or not
Thankyou
so i let 0 go after it started beeping but it wouldnt go to the warning menu, it just kept on trying to reboot, then said disk read error. what should i do?
hi, If the first suggestion didn't work try these steps,
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
let me know if it helps you or not.
Thank you
for some reason, none of these options are working
