Car Audio & Video Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a wiring harness for my honda to hook up my stereo deck and but it wont turn on, are the color codes different or just match the color to color??
Driven Audio Ltd
Level 2:
New Friend:
  • Expert 162 Answers
  • Posted on Feb 04, 2011
Driven Audio Ltd
Expert
Level 2:
New Friend:
Answers
162
Questions
0
Helped
51201
Points
317
If you mean you bought a wiring harness adapter for your car so you could hook up an aftermarket deck - yes it's just color for color then.
2answers
Wiring problems with Kia stereo
The simple solution would be to go to the source where she bough the system
Should i have any spare wires when hooking up an after market car stereo
Yes, It's a very good possibility that you will have a few wires left over. Normally a wire for an aftermarket amp to be triggered on when you turn your radio on and possibly a power antenna or a dimming function that dims your radio lights when your headlights are on. It of course always depends on if you have a power antenna or not, or if you have an aftermarket amp or not or if you have the dimming feature on your car or not. These wires don't apply to everyone.
You will just match the colors between the wiring harness that came with the DUAL radio and the interface adapter that goes to your car. Make sure you use **** style crimp connectors. If not the wires could come loose or cause a popping noise or cause the radio to turn off while driving.
Other than that, installing an aftermarket radio is mostly matching the colors up between the two harnesses and crimping the wires together.3_6_2012_2_31_36_am.jpg
1helpful
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Is there anyone who can answer a question re color codes for matching wires from harness to stereo i have a pioneer stereo and and need to install it in a honda civic need to match its wire colors to...
hoy cr*p. Thats a big question. I'm used to the simple hook up of red = hot wire, black equal ground wire, and white usually goes to the speakers. MOST electronic equipment use red as the "hot wire"...or the wire that is the main electrical wire. If your colors dont match, you might talk to a shop that specializes in installing car stereos. Good luck. thats how they make their money, but depending on the price you may decide not to mess with it yourself. Just label the wires with tape when you find out.
2helpful
Need to hook up stereo in 91 accord but its just open stereo wire
Below is the wiring setup for your car:
1990-93 Honda Accord Stereo Wiring
Constant 12V+ White/Yellow Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Best of luck,
Greg
1helpful
I want to take out factory radio to install stereo
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car.
After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck...
KEN
1helpful
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
After market stereo install
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
The wires for the stereo are cut
Yes this is not to bad to deal with.. make sure you use quality wire connectors so you don't have problems later with bad connections. you pretty much just have to match the colors from the harness in the car to the ones on your deck. If you don't want to cut off the harness connector on your deck just purchase one that you can connect to your deck and cut the wire ends on the other side of the adapter. The only wires you wont be able to match color for color is speaker wires... for these you will just have to hook them up temp. and test to see that they are connected to the proper speaker output. close.gif Read more >> Options >> answers-logo.gif
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
