I have a star grill max (seal max) hot dog roller grill. my problem is that the rollers no longer turn....the rollers still warm but will not turn. I have clean the entire grill and chain. the motor turns until the chain is hooked up and once the tension is on there it stops turning. please help it is only 4 years old
If your Candery hot dog roller is heating up correctly but the rollers are not spinning, there may be a few different causes.
Check to make sure that the rollers are properly lubricated. If they are dry or dirty, they may not be able to spin.
Make sure that the rollers are not jammed with any food particles or debris. Clean the rollers thoroughly if necessary.
Verify if the belt that connects the motor to the rollers is not broken or lose, if the belt is damaged or not properly adjusted, the rollers will not spin.
Check that the gear that connects the motor to the rollers is not stripped. If the gear is stripped, the rollers will not be able to spin even if the motor is working.
If none of the above steps work, the problem may be with the motor or control board, and the machine may need to be serviced by a professional technician.
I would recommend checking the user manual or contacting the manufacturer for further assistance, as they may have specific troubleshooting steps or solutions for your model.
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
