Heating & Cooling Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as tried several brands then it worked great for a week, turned on and off every time. Today doesn't work again at all. Turned a/c off at meter box as plugged direct into box. Changed batteries with new ones and other ones from other remotes a dozen times, pressed the reset several times. Nothing working. I am assuming it needs a new remote, I am in Qld, Australia, where do I get one?
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Feb 02, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953463
Points
6173
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1199
Points
I have lg lsl 122v-3 split system which dose not heat on cold mornings, say from 3deg outdoor temperature with ice forming on condensor.The time span is from 7am to 9.30 am.lg are absoluteley uselesson their site.Can any one help
5helpful
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
LG remote problem
Most probably if the remote works on the other units then the receiver on your problem unit is busted. You have to call an authorized service repair shopr to replace the board.
I hope it helps.
30helpful
2answers
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
3helpful
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
1helpful
3answers
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
2answers
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
