20 Most Recent
LG Art Cool LA181CNW Split System Air Conditioner Questions & Answers
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Error code 10
Check to see if condenser fan (condenser is the outdoor unit) is spinning freely
Can a 30 mfd capacitor run an 18000btu a/c with out any problem
Hi, Kasirye! 18.000 Btu A/C in most cases used 35 or 40 mfd cap. , during start up if the capacitor is too short it may hang and the compressor can heat up. But if you h've an amp. meter you can also measure the current of the compressor if it is in the range given on the name plate on the outdoor unit. Also you may check the charge of freon (example. 22) in the system. the suction has to be between 60-70 and the suction 225-275 psi (normal weather). If ihere is an over charge, you can have compressor overheating too!! I hope this was helpful to you!!
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
