Get the help for how to access Netgear Router login & setting ...http://comprehensive-support.blogspot.in/2011/04/how-to-access-netgear-router-login.html
To access the router you will need to open up your web browser and type in 192.168.0.1,it will then ask you for a user name and password ,the user name is admin,the password is password,that will get into the netgear utility for the router,that info can also be found on the bottom of router,if that doesnt work then you will have to reset the router to the default settings by holding in the reset button for about ten seconds located on the back ,you will have to use something that is small enough to depress it,you have to reset it while it is on,if you got it used then you should reset it anyway so that you can configure it according to your situation,ok have fun and good luck,you can get detailed info from netgears website.
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
On a computer that is connected to the router with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
