There is no switch along the lines of like a button or light switch. There is a thermo switch that opens and closes from the temp. If the compressor is running then its either a blockage or or leak in freon. You could use an amp meter and check the draw. Look on the manufacture sticker for the running amps. If your getting much more the double then it blocked. If the compressor is running and your amps are below 1amp its a leak and needs to be addressed by someone EPA certified.
Good luck,
Shawn
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
