Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ Wired Controller Logo
Posted on Jan 30, 2011
Pelican XSZ (model# PL-3601) wont turn on using my hp pav dv 7 series with Vista OS. It works fine on other pc. What is the problem?
HP Pavilion DVD player won't eject but plays the dvd
NO PC told PAV means nothing, PAV is both laptop and desktops for decades 10,000 models,+
the button on the try must work, it's electrical.
NO OS told is it windows, is it w8? or w7 or vista or XP>
The OS windows , you open local explorer. (this PC)
and right click the DVD drive and pick EJECT. that too must work
both must,
some APPS lock the DVD, , say a DVD player of any kinds
power off the PC
and turn it on and hammer esc key and at the prompt click F1 or F2
and go to BIOS page 1.
now the front DVD tray eject works, (button physical)
if not the DVD drive is JAMMED.
Hp pavilion dv 9728cl coprocessor driver
This is part of the nvidia chipset driver. Suggest you use this driver website
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9700-entertainment-notebook-pc-series/3632106/model/3647029
If you have windows 7 32bit, suggest you use the vista 32bit drivers, since 7 can do vista drivers.
If you have windows 7 64bit, suggest you use the vista 64bit drivers, again 7 can do vista drivers.
My laptop is an HP 2000 series (model dv 2800ee). Originally it was running on Winodws Vista Home Premium but recently i change the OS to Window 7 Ultimate. Upon changing the OS the following were NO...
With reinstallation of operating system you need to reinstall the drivers too
Here you go, sir
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3650945&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3675069&taskId=135
Quiero intalalor en mi pc
Conecte el adaptador inalámbrico. Ponga en el cd con los drivers para el mando a distancia 360. instalar el software. a su vez en el controlador. debería funcionar. Bam.
When i connect my wired xbox 360 controller into the usb slot of the xbox 360 console, the light on the controller lights up for about a second and then stops working completly. How could i fix this? If...
I can't help you much since i can't physically fiddle with it, but my best guess would be either a damaged USB port or the USB connector on the controller is damaged.
Cant get my xbox 360 to hook up to wireless internet
Hii go to the below link and you will find the complete details on how to connect xbox 360 to the wireless internet along with the screen shots..
http://tinyurl.com/raj321
Hi i am using hpdv6767tx after installing windows 7 my bluetooth driver stoped working.
The DV series laptopis not supported for Windows 7, HP decided the model is too old to support it....however since Vista and Windows 7 share a common platform, try searching for the Vista driver. Make sure to put into the search parameters either a 32 bit or 64 bit operating system. I have a lot of success using the Vista drivers for the DV6000 and DV9000 series laptops with Windows 7.
copy and paste the entire link below to your browsers address bar. Choose the operating system from the drop down menu, search for the driver from the list.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3675083&
1helpful
2answers
How to download hp pavilion dv1000 audio drive
my hp dv 1000 laptop exact model is dv 1693 and os is vista pls tell me about perfect audio driver for this model acxept hp web site
1helpful
How do i link the pelican remote to the xbox 360?
There should be several USB ports on your 360. There should be one in the back and two in the front lower part of the console. It is hidden beneath a small flap you can push in with your fingers and slide the cable into the usb
I've got a HP Pavilion DV 9700 with 3GB RAM, it's running Windows 7 professional 32bit. It has a video card Geforce 8600m GS, I downloaded the drivers from the Nvidia web page but the driver doesn't seem...
ITS a NOTBOOK, with fixed GPU. (cant change that)
so what was this PC new. what OS? VISTA
and you put on w7?
if yes, did you look up the rules for w7 on that. first.
that is step one, btw.
i think your OS was changed from VIsta to w7
try the Vista driver below. it might work,.
so why not use the HP drivers,for your PC and leave nvida out.
if the HP drivers fails, due to wrong OS, the ask Nvida for help.
not HP. see? If HP does not support w7 , asking them is fail.
first get right 32bit and 64bit, do that first. then pick W7
then pick GPU driver.
ask HP no matter.
they had Nvida chip or Intel, using the wrong chip driver is FAIL
Top Pelikan Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Pelikan Video Game Console and Game Expert? Answer questions, earn points and help others
