Heartland 3060 Bottom Freezer Refrigerator Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't cool. Lights come on when door is open. Power is ok. Compressor doesn't seem to be coming on.
Anonymous
Level 2:
  • Expert 180 Answers
  • Posted on Jan 30, 2011
Anonymous
Expert
Level 2:
Answers
180
Questions
Helped
58298
Points
509
Check to see if there is power getting to the compressor. If there is you probably just need to replace the overload relay that attaches to the compressor. There is the possibility you will need a new compressor, but usually you will hear something. There are 3 terminals on the compressor, one by itself, and two side by side. The one by itself is common, the other two are start and run. With a meter check common to start, then run. Both should be below 10 ohms and the start terminal has slightly higher resistance than the run terminal.
If you dont have power, you will have to trace power back to the control board, or the thermostat. I can give you more detailed instructions if you give me the full model number.
Hope this helps.
1helpful
F150 dome lights won't come on and power windows won't work when I open the drivers side door.
fuse needs to be replaced. probably in the engine compartment or under dash.
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 • Dishwashers
Power button indicates a cooling mode but I don't hear the compressor come on and the air coming out is not cool. Seems to have worked earlier this summer but sometimes the cooling seem spotty. Tried...
You may not have the temperature set low enough to make the compressor turn ON. Lower the setting until it does. This will give you an indication, where you need to leave it set.
Thanks for choosing FixYa.
2answers
Lights come on when door opens but does not seem to cool. Lights which used to indicate temp setting for freezer and refridgerator do not come on at all. Freezer is not cooling at all. But lights do...
The thing i would check was the main control board on the back on the side about a foot and half up LEFT SIDE. It seems to be that the things that are conrtolled by low voltage are out because the board has fried. In most cases it's pretty easy to see if the board is the problem, by removing the cover there and you will see soot and burnt components on the board.
Gene
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
The refrigerator side of my Samsung model RS265LBWP is not cooling sufficiently. The compressor is working and I have vacuumed out the dust from behind the access panel on the back of the fridge. The...
Open the door...Hold the button down like the doors shut even though it's not....If the evac fan comes on your ok ther.But if the fan doesn't come on that could be the problem...Also things pushed up against the sides keeping air from circulating
Good day, the door of my refrigerator left opened.and then it will not work properly. it will not get cold anymore and cannot produce an ice. what should be the possible action im going to do? thanks...
Since I can't see or physically touch the unit, you will need to do a little research.
Is the compressor kicking on? If it does come on does it cycle on and off normally? If the compressor doesn't come on at all and you have lights then your compressor is probably shot. Depending on the age of the unit, it might not be worth the expense to repair.
If the compressor seems to cycle normally, then I would suspect that a lot of moisture was sucked into the unit when the door was left open and ice developed in the freezer section next to the thermostat.
You will need to remove the food in the freezer section; then remove the shelves, then the inside rear panel to look for the ice. If there is a lot of buildup there then you can either defrost the unit by unplugging it and leaving the door open, or use a hair dryer to do it faster.
I`v got an american whirlpool fridge/,somehow the freezer door was left open (not sure for how long),but when discovered lights inside were flashing/clicking.the water dispenser/temperate control on the...
A serious problem You have to take assistance from a technician. Due to overload as the door was left opened either the compressor motor or the condenser is burnt out. Please have it checked up. You will not be able to repair it yourself as it may require replacing parts.
3helpful
Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Light is blinking but the light bulb is good, cooling seems worki
no lights and a clicking noise when the doors are opened??? control lights also are out, but appears ti be still cooling??? if this is ht eissue you have a problem withte control board, located behind the refrig mounted next to the compressor in a white enclosure. call the manufacture or local part distributer for part, you can replace yourself!
Top Heartland Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Nitesh Kumar
Nitesh Kumar
Level 1 Expert
Gift Nzan Agbiji
Level 1 Expert
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
