Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Nov 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MODEL NUMBER CPLEF398CCB. I tried to use the self clean and I received the f9 message. I am able to unlock door and you see the lock moving from lock to unlock. It unlocks every time i clear and restarts trying to clean but always returns to f9 message. I also tried turning it off and holding door switch. How can I get it to work?
Sal De
Level 3:
  • Frigidaire Master 2,699 Answers
  • Posted on Nov 13, 2017
Sal  De
Frigidaire Master
Level 3:
Answers
2699
Questions
0
Helped
1003353
Points
8029
You either have a bad latch assy. or a bad computer board or a broken wire.this can be an expensive fix and the problem with self cleaning ovens is when you self clean them the temp. gets up to 1000 degrees and this damages the electronics in the machines,personally i would never use the self clean feature i clean mine by hand with easy off.people do this near the holidays and then the oven doesn't work parts have to be ordered and it could take up to 5 to 10 days or longer to get parts.don't ever self clean your oven when a holiday is coming up so this doesn't happen.if you can still use the oven just forget about the self clean if the error keeps you from cooking you'll have to find out what part is bad to fix it it sounds like your latch is working this code means the computer board thinks the door isn't locked if you want to change out the latch motor it's pretty easy,unplug the oven,pull it out and remove the back wall,the motor will be on the top right hand side looking at the unit from the back the part number is 316464301 this part is around 55 to 75 bucks depending where you get it now if it still does it the clock assy. is around 300 bucks part 316207600 so i would change out the latch assy. first if you need this repaired.hope this helps you out one more thing did you try unplugging the oven it could reset the computer board,leave it unplugged for 10 minutes and then plug it back in,don't try to self clean it,put it on bake and if the code doesn't come back great who cares about the self clean
1 Related Answer
Anonymous
  • Posted on Feb 23, 2009
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
1helpful
Self clean cvode F9
Hello there:
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
replace parts as necessary
2helpful
F9 code on unit. Oven door locked
Yes, the error code F9 means that the door lock circuit is faulty and should be checked and replaced by a technician. I can supply you with a part number if your able to locate the model number. Which can be found usually on the inside of the pots and pans drawer at the bottom, OR on the back area or the stove. Usually will begin with letters followed by numbers. Hope this helps
Thanks
Jan 02, 2010 • Ovens
1helpful
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 • Ovens
4helpful
3answers
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
2answers
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
The lock switch is on and door is open-"dr" then "f9" message
Unplug the range and then have someone hold in the door/light button while plugging in the unit again. The locking mechanism should reset itself. Let me know if I can help further.
Waiting to hear from you,
Eric Campion
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
142helpful
10answers
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
