Watches Logo
Posted on Jul 18, 2008
How to set armitron digital watch 45/6915?
Is any body can help me how to set this armitron digital watch 45/6915?
There is 4 buttons 2 in the left (adj atthe top and mode at the buttom) and 2 in the right. (ST/STP at the top and light at the buttom).
Could you please let me know how to set this watch.
Thank you so much.
  • ahbies Jan 06, 2009
    My son has the WR165 watch and we have lost the instructions. On the left of the watch is the; ADJ (top button), MODE (bottom). On the right; ST/STP (top), LIGHT (bottom). We need to know how to set it.
  • gmosher Apr 21, 2009
    Need manual for setting 45/6915 Armitron WR165
MetriRN
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 21, 2009
MetriRN
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
18467
Points
18
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
Set time
Hi ajandmjm,
Please follow the steps below to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
23helpful
Set the time on a Armitron WR330 40/8125 All-Sport watch
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
Hope it helps.
5helpful
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
Hope it helps.
I need set the date of my Armitron watch Thank you
Hi diazlieter,
To set the date of your Armitron watch, please do the following.
Hope it helps.
32helpful
2answers
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
Hope it helps.
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
Hope it helps.
How do you set the time for a armitron 40/8125blk
Hi bob110352,
You can easily set the time of your Armitron watch by following the steps below.
Hope it helps.
I bought a ladies armitron watch.. and can't reset time.. day etc is fine.. the symbols left hand side say 'set' 'mode' right hand side 'ADJ' 'AL' ... can you help.. Thanks Leanne
Thank you for contacting FixYa.
  • Look at your watch as if it were a clock face, even though it may be a digital. Most Armitron watches have four buttons around the perimeter of the watch. There will be a button at the 2 o'clock position; this will be button "A." There will also be a button at the 4 o'clock position. Consider this button "B." On the opposite side will be button "C" at the 8 o'clock position and button "D" at 10 o'clock.
  • Press the "D" button until the numbers begin to flash on your digital watch. Press and hold the "D" button again until the seconds begin to flash by themselves. Press the "B" button to advance the seconds. You may hold down the button in order to cycle through the numbers faster.
  • Hold down the "A" button in order to move on to setting the Armitron minutes. Once they begin flashing, press the "B" button just like you did to adjust the seconds. Press the "A" button one more time, and you will see the hours flash on your watch face. Hold down the "B" button and cycle through, making sure the a.m. and p.m. is correct.
  • Change the date on your Armitron watch by once again pressing the "A" button. This should cause your date to blink. Press the "B" button to change the days.
  • Cycle through the months by pressing the "A" button one final time and holding down the "B" button.
  • 124helpful
    3answers
    Ladies Armitron 45/6967
    Armitron alarm/chrono
    1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
    2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
    Hope this helps!! K~~
    1helpful
    2answers
    Can't set time on a 2 button armitron watch
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
    Mar 10, 2008 • Watches
    Top Armitron Watches Experts
    Gene Lawson
    ADMIN Andrew
    ADMIN Andrew
    NOEL
    NOEL
    Are you an Armitron Watch Expert? Answer questions, earn points and help others
