We got a 19" Orion tv at a yard sale. It came with an RCA universal remote. When it was plugged into the cable, the remote will only access channels 3 and 4. How do I get the tv to go to other channels?
If holding down both volume buttons won't let you into the menu you may need the original remote. Call the phone number on the set. They may still have it available.
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
I found 3 codes: 1030, 1035 and 1191. Code
1030
for
Orion
TV
Code
1035
for
Orion
TV
Code
1191
for
Orion
TV
For other devices, try the remote code finder http://remotefinder.rca.com/default.aspx?site=rca . Try the search twice if it gives you a problem the first time. At times, the search engine has server issues. Please note that if the remote was programmed less than 6 months after the TV was released or is older than the TV, the code you need may not be part of the programming. In that case, you need a newer remote or one that is programmable (via a computer's USB port for example).
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
The 'universal' remote isn't; they are just cheap.
You may find an original here:
Remotes Someone should bring a suit against any of these
manufacturers using the term 'universal.' At best, they are 'multibrand' and, with the
proliferation of 'brands,' there never will be one that can rightfully claim to
be 'universal.' There may never be a code for your brand
available in every remote.
