Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS)
and remove at least 1 battery from each column of batteries. After 2-5 seconds,
reinsert the batteries and turn the unit on. This will cause the unit to reboot
the operating system.
Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the
battery door (for TI-Nspire CAS) and remove at least 1 battery from each column
of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF
(do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is
a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press
[On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc]
[Enter] [EE], and while holding these keys, press [On]. The device will boot up
as in the previous reset, but will display a menu with the following options.
Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at
the top right of the TI-Nspire keypad and has a picture of a house on
it.
Hello, Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note: • TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hello, Here is what the TI knowledge base says about a calculator failing to turn on.
operating system.
operating system.
operating system.
operating system.
Hello, Try these, courtesy of the TI Knowledge Base
operating system.
Hello, Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
operating system.
Note: • TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above. 1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
operating system.
