Google Chrome Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can´t load swf
Anonymous
Level 2:
  • Expert 187 Answers
  • Posted on Mar 19, 2011
Anonymous
Expert
Level 2:
Answers
187
Questions
0
Helped
35362
Points
699
You need to install latest Google Chrome Adobe flash player plugin.
You can find the steps in this LINK.
or copy and paste this on your browser:
http://blogote.com/2008/ideas/browser-ideas/install-latest-google-chrome-adobe-flash-player-plugin.html
The boxes that show a picture of each movie is blank (empty) but if i click the box the movie will start playing. I have windows xp.
Some web browsers have the option not to show images. Have you checked your options page?
Nov 03, 2013 • Netflix
tip
IMovie export Flash FLV/SWF, iMovie export for web with iMovie to Flash...
iMovie is an excellent and easy-to-use editing program that is produced by the Apple Inc. Once you have finished your editing, there are a few movie formats to export.
Export iMovie to Quicktime
1.To save the imovie video as quicktime file, Go to the "Share" menu and select "Export Movie..." option to open the "Share" window, then choose "QuickTime" icon.
2. In the "Compress movie for" pop-up window, select an option and press "Share"
3. To choose the type of export format, click "Options" button to set the compression, frame rate and key frame. Then click "Save" and the imovie video will be saved on your mac.
Export iMovie to DV Tape
You can save your movie finished with iMovie as a raw digital video format on DV tape
1. Get a blank DV tape in your camcorder and connect your camera to your computer with a FireWire cable, then set your camera to VTR mode.
2. Go to "Share" menu and choose "Export Movie..." option to open the "Share" window, then choose "Videocamera" icon. Finally click "Share" button and wait for a moment, your movie will be saved on your DV tape.
Export iMovie to iDVD
You can export iMovie as a file which can be workable with iDVD for burning a home DVD.
1.To export a file to iDVD from iMovie, Go to "Share" menu and choose "iDVD" option.
2. Press "Share" button and choose a destination for it and click "Save".
Export iMoive to Flash FLV/SWF for web
You won't find any export option in iMovie for exporting iMovie file to Flash(FLV/SWF). So how should you do to export imovie to Flash for your website? One tool is required, that is Doremisoft Video to Flash converter mac. Therefore, when you have done your movies in iMovie and would like to add the movie to your website, you can achieve it by the ways of exporting iMovie movies to hard disc as a Quicktime clips and then converting Quicktime movie to Flash FLV/SWF with the mac video to flash converter.
How it works:
1. Export iMovie movie to Quicktime(See the above details)
2. Download, mount and launch the video to flash mac converter. Then click the "Add Video" button and go to the video folder where video clips exported from iMovie is stored, choose them. Finally, hit "Open".
3. To set the output format, open the "Step2 of Customize" window and you are allowed to check "Generate FLV or Generate SWF or Generate HTML" to set FLV or SWF or html page embedded with flash video as your output formats.
Tips: You must choose either Generate FLV or Generate SWF or both. If you haven't check Generate SWF, you can't choose Generate HTML and if you haven't choose Generate FLV, you can't choose Generate SWF-->Play the created external FLV file progressively. If you choose Generate SWF-->Play the created external FLV file progressively, Generate thumbnail is selected automatically.
4. To select a flash preloader template, click "Next" button, hit the "Preloader" button and add a flash preloader to your flash video.
Tip: This step is valid only when Generate SWF-->Embed the video in SWF and play in timeline is select at the last step.
5.When all settings has been done, it is time to start iMovie to Flash FLV/SWF conversion. After conversion, you can upload the flash video to video sharing website or post them into your webpage.
Next: Convert DVD to Flash & embed DVD in website and blog.
on Jun 22, 2010 • Computers & Internet
tip
Flash video from Fianl Cut Pro, FCP export Flash video for the web FLV SWF
If you have installed Macromedia Flash 8 in your mac, you will have an FLV video exporter into Final Cut's QuickTime conversion menu and then you are able to directly export Flash video(FLV files) from FCP. However, Flash 8 might not be the right option for you for its expensive or it can't assist you to export SWF file. Then you have a suitable choice, that is, FCP to Flash(FLV/SWF) converter.
With FCP to FLV/SWF(Flash) converter, you are able to convert a movie created in Final Cut Pro to Flash FLV/SWF or generate a HTML web page embedded with skinning and customize Flash player with a few mouse clicks after you export movie from Final Cut Pro as QuickTime movie. This workaround is simple-to-use yet professional, suitable for both beginner and experienced mac users.
Step1. Export Video from Final Cut Pro
After editing video with FCP, Use File > Export > Quicktime Movie to export video from Final Cut Pro. And its exported video is in the MOV format.
Step2. Launch the FCP to Flash converter and add FCP movie
Double click its item to launch FCP to Flash converter and click "Add Video" button to import FCP movies.
Step3. Choose the output quality
Click the "Customize" button and in the "Profile" field, then according to your requirement, choose the output quality: F4V, High quality, Low quality, Normal quality or Custom.
Step4. Start FCP to Flash conversion
You just need to click the "Start" button and the FCP to Flash conversion will start automatically.
About Final Cut Pro
Final Cut Pro shorting for FCP, is a professional video editing software program developed by Apple Inc for mac users, which offers pro-level editing for people who had hit iMovie's ceiling and wanted more editing control and options. As part of the Final Cut Studio, Final Cut Pro allows video editing for highest-possible quality and mix frame sizes, frame rates and formats in the same Timeline in real time.
Next: 8 Tips for create FLV/SWF/HTML web video(Part I).
2helpful
301:unable to load plugin: unable to load plugin, url flowplayer.controls-3.2.3.swf, name controls - this is my question i got this error when i play flash player
had that issue on my watch free movies online website and i have managed to solve that error by combining the right version of swf files.
Follow the site and look at the page source to see the version of swf files i use. hope this helps
2helpful
Cannot open a protected movie
You'll need the original .fla file. Or decompile it using something like this.
tip
Convert WMV to Flash FLV SWF with flash player for web/blog
WMV to Flash convert software----add wmv movies to website/blog
WMV to Flash convert software----is it really a helpful tool for webmaster to have? If you would like to add WMV video to your website to share funny movies, promote products for attracting more traffic, there is no doubt that this program is indeed a help. In the following tips you will learn how to add WMV video to web page within a few minutes.
Short Description:
WMV to Flash convert software is able to convert WMV clips to Flash video(FLV, SWF) and embed WMV movies in an HTML web page automatically. What you need to do is just to add the HTML code to your webpage and then upload the output files to your web hosting server. Without any programming knowledge, you can add video to your website.
Have a Try
Important Outstanding Features:
1. Easy----with a few mouse clicks, no actionscript need
2. Powerful editing function: crop, clip, merge, slide(create a video playlist), add video effect, etc.
3. Enables you to create web video with controls, skinning flash player
4. Empowers you to add text/image, URL to web video as watermark
5. Provides you with fantastic special effect, preloader template
Note: If you are a mac user, Please Download its Video to Flash Converter Mac Version.
on Jun 17, 2010 • Computers & Internet
2answers
Flash Buttons
After creating a Flash movie you choose File > Save As from the top menu to save your movie. Save the file as "Somefilename.fla".
To embed the Flash movie you just made into an HTML page, you should go back to your Flash program and do the following steps:
Step 1
Choose File > Open. Open a Flash movie you have created.
Step 2
Choose File > Export Movie.
Step 3
Name the file "somefilename.swf". Choose the location where the file is to be stored (in your Web folder). Click OK.
Step 4
Open the HTML page where you want to insert your Flash movie. Insert this code:
<object width="550" height="400"> <param name="movie" value="somefilename.swf"> <embed src="somefilename.swf" width="550" height="400"> </embed> </object>
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
