SOURCE: Game setting on a Sylvania TV
Most T.V.'s will let you use the front buttons, keep going down to zero and it should go through them. if not ( becasue i know some just roll over) try getting into the menu settings and it might be in there.
You best bet, go to ciruite City or best buy and get a $20 universal remote, check the back and make sure you t.v. is listed as one of the models it can be used on. This is a cheap quick solution. T.V.'s use infered beams to transmit, so there all the same, just different in its signal range. each brand usually has there own that they stick with so you just get the remote, program it according to the instructions and it should work.
SOURCE: auxillary without a remote
I would try going to the manufacturers site and downloading the manual if you don;t still have yours.
SOURCE: How did you get the sylvania tv into game mode with out remote
I had to use a dishnetwork remote that I had lying around. You also may able to program a direct tv remote, replaytv remote or universal remote. I have found that putting it into 'game mode' does not work. You will not be able to change the input without a remote.
Here are the instructions for the dishnetwork remote I was using (may differ slightly from yours):
Sylvania Television codes: 733, 506, 525, 536, 566, 568, 569, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729
1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
2. Look up the Code(s) for the piece of equipment you are trying to address. If the equipment is not listed or a Power Scan is desired click here.
3. Press and hold the correct Mode button (about six seconds) until all mode button backlights come on, then release.
4. Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
6. To verify the code works, press the mode button. Then try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
7. Store the remote code for future use.
8. If the remote still does not operate the device, perform the Power Scan. If still no operation, it may not be compatible with that piece of equipment.
SOURCE: Sylvania TV Headphone Jack Problem (Specifically
If the audio jack [headphone] has two black bands then it is probably stereo. The first reason you tv phone jack is messed up is because you have an internal ground problem. You may have to resolder this...hope the board is not cracked. I would not advise you to jury rig an outside connection. To do so, you may short the audio chip and that is another problem...like no audio at all. Find someone who knows something about tv repair.
Testimonial: "Thanks very much for the followup which lead me to realize the jack must be mono and must have an internal switch--with the flimsiness of the jack, it"
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
