I'm trying to figure out wich engine is in my 706 gas? according to the serial number the tractor is a 1965. I cant find any engine serial number? and they say a 706 would come with a 291 or a 263 ci? Any body got a idea?
Your number does not seem to match what I could find. Please check the serial number plate on the left side of the 706 clutch housing, driver side.
1963: 501
1964: 7073
1965: 21162
1966: 30288
1967: 38521
Final: 46647
I couldn't find the exact year from your serial number only a year range which is 65-71.
Your serial # breaks down as follows.
34 = 1965 - '67: J-3000 4WD,
Gladiator or1968 - '71: J-4000 4WD,
Gladiator 06 = 1965 - '70: Cab & Chassis, Truck or 1971: J-2500 Cab & Chassis,
Truck (This means it did not come with a bed from the factory.) X = 1965 - '67: 6000# GVW or 1968 -
'70: 6000# GVW, also console shift Wagoneer (1414X) with
exterior metal type feature panels or 1971: 6000# GVW, J-4600, also
console shift Wagoneer (1414X) with exterior metal type
feature 1 = 1965 - ' 71: Left Hand Drive
You should be able to narrow it down a bit more, however it's going to take comparing pictures of the various years within 65-71 and looking for changes to the style such as grills, headlights etc.
carb is probably gummed up from the old gasoline. try squirting some gas into the carb where the air goes in to start it. probably won't keep running but sometimes it can shake something loose like a stuck FlOAT VALVE.
