Possibility of mechanism fault inside the VCR, which might include tape damage. Can't answer directly about the 03 code, without knowing make or model number as they all use different fault codes.
Taking the top cover off might show up what's happened.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
I answered this previously, thinking you were referring to the machine, not the tape itself. See if a different tape (perhaps even different brand) works okay. If not, look at the machine. I have seen tapes go bad, but generally it is the machine (or camcorder).
Take out the tape and press play, do the wheels move? if not the motor has burnt out, the tapes may have been sticky. Hold a tape and wind the wheels with your finger, are they difficult to move?
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old. I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Hello Can you hear the motor running, when you press any of the Play, Rew or FF buttons?. Just place your ear very close to the player and listen to it. If the answer is 'yes', the drive belt is broken or slipped off. You have to replace the drive belt. If the answer is 'no' the motor of your device's drive mechanism has damaged, and should be replaced. OK.
WISH YOU A PROSPEROUS 2012. Gopakumar G, Kerala State, South India.
There is a small pencil dia, into which a lever enters to unlock it on the underside of the cassette which when pushed in and unlocks both sides on which the tape enabling FF & RW & PLAY. The pin must have got its angle changed or manged to change wile removing the stuck tape..................sodeep
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
