SOURCE: Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
SOURCE: Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
SOURCE: My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
