Toshiba 46HM95 46" HDTV Logo
Posted on Apr 01, 2017
I have a color flickering problem with my Toshiba DLP 46hm95. It flickers images to different colors. However this only happens in both HDMI ports. there is no flicker through antenna, colorstream HD, or from the dvd player. I ruled out the HDMI cable, as it worked fine for my other tv. Can I rule out the color wheel being the isssue, since it works in the other ports? I have noted a slight dimming recently....will a bulb ready to go out cause this color flicker? The only other option i see is the hdmi from the hd cable box, but I doubt it would be the problem. I wanted to ask the other questions before i go through the hassle of disconnecting cable boxes and checking them.
5 Related Answers
Mike McWhinney
  • 537 Answers
  • Posted on Dec 20, 2007
SOURCE: toshiba dlp
The light engine part number is 234054 and cost $456.00
Anonymous
  • 150 Answers
  • Posted on Apr 24, 2008
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
tlm931
T.l. Moore
  • 273 Answers
  • Posted on Jan 16, 2009
SOURCE: My Toshiba 55" TheaterviewHD works
it sounds like a convergence problem and there are different settings for 720 and 1080 in the service registers
Anonymous
  • 25 Answers
  • Posted on Feb 06, 2009
SOURCE: Picture flickers on all inputs.
If your having pixelation,try disconnecting other tvs
from the wall.you may have a noise or DB drop off or surge issues.check all splitters from the tube to the soffit of your home.If you find one upside down out side ,water maybe be getting in.Remove all snap adapaptors,screw on only.Splltters are
cheap,,easy way is spend $3 extra a month to have your cable Co repair or replace any seeping cables or adaptors and/or splitters.
Anonymous
  • Posted on Jan 24, 2010
SOURCE: Flickering grid of blue squares on the screen
I have the same problem
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
There are flickering, rainbow-like color bands running across the screen, especially in the component inputs, not so much using the HDMI input, but still there.
Hi,if your tv is and Lcd rear projection it will be the light engine that needs replacement.Because lcd technology uses 3 chips green,red and blue that create the image and colors.When they start to fail you will get what you are getting color discoloration and rainbows.If your tv is DLp it will be the dmd chips which basically its like the lcd chips but instead of 3 chips its only one that creates the image.Hope this works God bless you!
3helpful
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
77helpful
21answers
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
3answers
Dlp picture problems
dear,
if you have checked it by changing the lamp then there you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but dear plz dont touch that one.
regards,
2answers
Toshiba dlp
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
