This is easy these are bad moniters and are okay when you normal one blows up this is a known glitch with the series but of course im not going to be one of those critizisers that do not offer a resolution which leads me to the answear the resolution to remove it change the resolution if your using windows go to star>controlpanel>displays>resolution change it you might have to do it a couple of times and its not a full fix but its the only one
I couldn't get the Neovo on-screen display (OSD) off the screen. I tried every suggestion online and nothing worked. The F-417 manual was no help. Then I turned off the computer, unplugged and re-plugged the power cable to the monitor and unplugged and re-plugged the connection between the monitor and the computer. It worked! The on-screen display was gone! Everything was back to normal!
2, 3 pichote la ou ya les boutons en bas de l'ecran devrais regler le probleme !! j'ai essayer de tout simplement depluger la carte de controle des boutons. (ne functionne pas)
okay sticky button I figured that out already how do you on stick the sticky button. I thought there were experts on this site????
