Nokia 6230 Logo
Anonymous Posted on Jul 12, 2008
Sim card rejected
My phone says sim card rejected. It is the sim card that came with the phone. Good evening sir, my mobile create a problem in which it display on the screen is sim card rejected. my sim card is rejected after i put in the puk code and then it asked for my password i put it in and now the sim cards rejected
  • Anonymous Mar 27, 2014
    Sim rejected due to wrong code
Anonymous
Level 3:
  • Master 983 Answers
  • Posted on Jul 13, 2008
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434527
Points
2838
This happen if there is some problem in the sim card holder port ....
there will be loose contact inside the sim card holder is not touching the circuit board inside due to this your sim card is getting rejected ...
as you have told that the phone is a brand new one so i am sure that you will be having the warranty so just make use of it by contact the dealer with whom you have purchased or contacting the company customer care number to get more information about how to make use of your warranty ......
if you dont have the warranty then you must open the handset
and just remove the circuit board & sim card holder and insert it again so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if you just open the handset & set that sim card holder to touch the circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
  • Anonymous Jul 13, 2008
    it will ask for the PUK code when you try inserting the wrong pin
    for 3 times ...
    so to get the PUK code follow these steps:
    1. call to your network provider s customer care from some of your friends number of the same network ...
    tell your number & ask them for the PUK code..
    2. they may ask you the details of sim like in whose name it is etc..
    answer that ...
    3. after that they will provide you the PUK code note it down
    4. enter the noted PUK number to your cell ...
    5. your sim will get unlocked ....
    caution:
    if you try inserting the wrong PUK codes for more than 5 or 10 times it
    will completely block the sim after that you must contact the network
    provider s shoppe only to get it unlocked ..
    remember this ...
    this
    solves your problem ...
    thank you
    bye
    dnt forget to rate my solution
4 Related Answers
A
Anonymous
  • Posted on Jun 03, 2008
SOURCE: sim card rejected
what can i do if the mobile tell me sim card rejected
Anonymous
  • 157 Answers
  • Posted on Aug 03, 2008
this is because ur phone is locked to a provider. you'll need to unlock your phone first and then u can use ur phone with any sim
Anonymous
  • 270 Answers
  • Posted on Nov 06, 2008
this happens when ur sim cant establish registration with the preffered networkk . this is not a phone problem . ur sim card may not hve been used for long time (recharging account) . please contact the nearest office of ur network provider
Anonymous
  • 41 Answers
  • Posted on Jan 06, 2009
hi
you can call the company from another phone and fix the problem by giving them the PUK number.
i hope this will work
3helpful
I have samsung virgin mobile model no.SCH-B309 but sim shows that uim card rejected what can i do sir please help me and provide me uim no..
you can solve your problem easily,your uim card which is rejected by sim :firstly your uim card insert correctly or not secondly your sim card placed correctly or not if not both you insert the card correctly otherwise your must be phone off because sometimes phone hanged.
2helpful
3answers
1helpful
Sim card rejected
hi
3helpful
2answers
Sim card rejected
20helpful
6answers
Sim card rejected
When i open my nokia 5800 it says sim card rejected what can i do helpppppppppppp
Sim card rejected
Sim card rejected
this happen if there is some problem in the sim card holder port ....
thank you
bye
rate my solution
Sim card rejected
Try inserting the sim card in another phone. If it still doesn't work, the problem could really be with the sim card. Go to your service provider, and request for your sim card number transfered to another sim card. That is if you wanna keep the same number. You could request for another sim card if you'd like. Call your service provider.
13helpful
9answers
Sim card rejected
You need to do some testing first.
Put your sim card on another phone (should be unlocked or the same provider) and see it it works.
Put another sim card on your phone (should be the same provider sim) and see if it works.
From there you can check where the problem lies.
2helpful
6answers
Sim card rejected
my mobile create a problem in which it display on its simcard rejected.
Jul 28, 2007 • Nokia 1100
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
