HEY GUYS:
WHAT DRIVERS ARE AVAILABLE TO RUN MUSTEK - PVR-H140 IN A VISTA ENVIRONMENT. CAN I USE IT AS AN EXTERNAL HARDRIVE OR POSSIBLE MUSIC BACK-UP UNIT. I'VE HAD THIS UNIT FOR SEVERAL YEARS & WOULD LIKE TO PUT IT TO GOOD USE IF POSSIBLE.
THKS,
SMOOCHEZ
HI,
the drivers for the unit are available at http://www.nodevice.com/driver/_PVR-H140/get33981.html
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
G.
need vista drivers
I need Vista Drivers for PVR H140. If anyone knows a work around please share.
