20 Most Recent Mustek PVR-H140 Digital Media Player Questions & Answers
Hmm, what software are you using to convert your movie? and do you have the same problem if you copy a movie directly from a DVD? try doing that if you haven't already.
The supplied convertion software is awful, very badly written and a waste of time, I use "Arcsoft MediaConverter" it works well is fast and is just a simple drag & drop interface.
G.
Mustek PVR-H140... | Answered on Jan 16, 2013
The PVR h140 works on mpeg1 or mpeg4 format. If you need to convert avi files for example you will need a third party conversion programme such as Nero7 or similair free programmes. Check here for a 'how to' page. http://www.sharewareguide.net/article/Guide/guide:how-to-convert-video-to-mpeg4,-such-as-avi-to-mpeg4,-mpeg-to-mpeg4-and-vob-to-mpeg4-with-this-mpeg4-converter.html
You are going to have to start again, first connect the unit to your computer copy anything you want to save piccys movies and stuff but not the corrupted music files, Format the drive, then goto http://www.nodevice.com/driver/_PVR-H140/get33981.html download the driver files and re-install to the PVR, then copy all your mp3 files back.........
Mustek PVR-H140... | Answered on Feb 23, 2011
You mean the Frame dir ?
Mustek PVR-H140... | Answered on Sep 12, 2010
hi they told you to swap the hard drive but how do you copy the firmware onto the new drive windows wont let you copy the folder
Mustek PVR-H140... | Answered on May 03, 2010
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Mustek PVR-H140... | Answered on Jan 17, 2010
This happened to me too. Just unscrew the 4 screws, lift out the hard drive and glue it back down to where it was (2 little pegs will fit into two little holes on the circuit board. You can touch the contacts with a thin tipped soldering iron if you want to but you probably don't need to.Then close it up. That worked for me!
Mustek PVR-H140... | Answered on Jan 03, 2010
Battery spec as per manual 1000m Ah x2 doesn't give the voltage but the charging addapter is 5volt 2.0amp.
George
Mustek PVR-H140... | Answered on May 27, 2009
You may already know this, but tap the power button once more and it may turn on the screen.
Mustek PVR-H140... | Answered on May 18, 2009
Hi, If you haven't solved this problem, I would be interested in buying the Mustek for spares - let me know. d_ponsford@hotmail.com
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Mustek PVR-H140 Digital Media Player Logo
49 questions posted
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mustek Audio Players & Recorders
Most Popular Question
ac power jack came loose from board
  • Audio Players & Recorders
