SOURCE: advanced hybrid system panasonic kx-t7730
pick-up phone, press 77+hour and minutes (ex.0510-for 05:10), than press 1 and # for PM, or since 1 for AM.
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
SOURCE: HOW DO I CHANGE THE TIME ON A PANASONIC KX-T7730
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
SOURCE: How do I change the time on a KX-T7730 phone?
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
6. Press PROGRAM to exit program mode and you
are done.
