SOURCE: 2004 santa fe not shifting into over drive
have the modulator checked on the side of the tranny i would take it to a shop asap before the other gears start to go out on it as well
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
SOURCE: axel removal on 2004 hyundi santa fe
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?partName=Drive+Train&pageId=0900c152801a5958&partId=0900c152801a5958
Here is a link to autozone.com that has step by step instructions a diagrams for that
SOURCE: 2004 hyundai santa fe drain plug
Hi
I am very assumming that you are looking for the drain plug for the rad, right? It is located in the bottom of the rad, right side of rad standing in front of it. You can excess it with a philips scewdriver through a hole in the sub frame.
