Battery charger shows that the battery is fully charged - the green light is on. However, when the battery is reinstalled the drill doesn't operate??? Help!!
Re: Battery charger shows that the battery is fully...
Your battery is only good for so many cycles, it sounds like you need a new battery. Check with Batteries plus they're a great source for about ANY battery
I have the same problem with mine. I charged the battery on my Dad's charger and it works fine. Green light is always on on my charger. Appears to be the charger is brokenI have the same problem with mine. I charged the battery on my Dad's charger and it works fine. Green light is always on on my charger. Appears to be the charger is broken
You can't post conmments that contain an email address.
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery. http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Try jump starting the battery. Li Ion batteries often have smart chargers if the battery gets to low the charger doesnt recognise it. If yo have a spare battery fully charge it ant then conect + to + and - to - with wire ( may take two people) kep them connected for 2 mins or so then try in the charger.
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
