You just need to go to the BELKIN Support website and select your exact model of USB adapter as well as the operatin system that your computer is running. Here is the link to the support website:
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
When you find the driver for your model of USB adapter, just download the file and run it, then follow the onscreen instructions to install your USB adapter.
Hi, Try to avoid buying a adapter as the compatible ones do not wirk properly and if you try to buy a original one then the cost will very instead of buying a new router will be cost effective.
If you have a hard-wired (plug in) internet connection, you can download what's called the drivers onto the computer. That's what comes on the disk. If not, download and save the driver file from the website onto a flash drive or burn it to a disk from the original computer you used the USB adapter on, and run that file from the new one.
First the router's power adapter is already busted if you happen to have a spare or another power adapter with the same output as the original one try it first before deciding to purchase a new one.
Second, the routers processor or the entire board insed the router is already shorted, if it is still under warranty(this model has a lifetime warranty according to the specifications) send it back to the store where you purchased it or to Belkin(some manufacturers and stores also provide replacement for faulty power adapters).
I would suggest to check the plug on the av700 and see the polarity, it might be indicated there.
In regards to using any adapter, you could as long is the same polarity. The original adapter is 6 Volts and 2 Amperes.
