First
perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar
into the bottom of the dishwasher. Keep the temperature at the highest
setting possible and perform a wash cycle.Then start using a dishwasher
most probably that would solve the problem. If this does not solve the
problem then there must be some parts worn out or faulty creating the
problem.
There are many probable causes of failure .
To
clean the dishes the water temperature is essential.It the water is not
hot then the dishes will not be cleaned properly.So check the water
temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
SOURCE: dishwasher is not cleaning dishes
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
SOURCE: ge pdw7300 leaking water
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
kuyeyu
