Make sure the plastic tab is completely removed from under the store battery pack. My tab broke and we had to take the watch apart to remove it. Once we did this, the watch worked.
Hope this helps.
If the watch turns on while it is on the charger it is just the demo tab. When you took out the demo tab a piece must have gotten stuck. You can take it out with a pin or tweezers. If that fails unscrew the 4 screws and take it out that way. If that does not take care of the issue then it is defective.
whenever i connect the watch it says usb port not recognised
