How do you start this generator? Simply turn the key after pulling out choke? Is there a power (on/off) button somewhere that also needs to be turned on?
* check and clean out air filter.
* drain out old fuel from lines around on/off fuel valve.
* You may need to drain and force flush out fuel filter (I used the carborator cleaner to force out water in filter.)
* re-assemble fuel lines and clamp.
* pull out choke lever to full choke.
* Pull start cord (or start switch) several times to prime fuel line.
* Turn on switches to ready generator for start up.
* Try several times to start.
* If it won't start then spray in carborator cleaner or Generator start spay into the air intake (with air filter sponge removed. Just a short burst is needed.
* Try starting again.
* Pull at least 3 times before spraying any additional cleaner to prevent flooding.
* If generator does not even turn over then there is a spark or ignition problem. Pull the spark plug to clean and check gap. (see your specs for recommended gap.)
* try spray starting method again.
* if your still having problems (with not turning over at all) then you will have to take it to a small engine shop or contact the vendor for service. Check your warranty.
* Once the generator has started. Keep it running till smooth operation. Adjusting the choke to normal open position may take a few minutes till the engine has time to warm up. Install air filter and close up all covers. Allow for a 5 min run and check by connecting a load to the electrical out put. (plug in a saw or other heavy duty power tool) The generator should adjust to the additional load.
Aloha, ukeboy57
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it.
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
The pull cord is like a starter on a car (separate
from the motor/engine). If the pull cord will not turn it could be because the
motor/engine is seized.
There is an air leak in the seals somewhere between the carb and the intake manifold. You are getting too much air! ALL of those seals need to be changed, As the paper seals age they develop small cracks that kill the vacuum made by the engine to pull in the gas/air mixture!
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Take the spark plug out, connect it back to the wire, and rest it so it is touching metal, Pull the cord and see if you see a spark. If you see a spark that means you are not getting gas. Put a few drops in the hole and replace the spark plug. Pull the cord with the choke off a couple of times and it should fire up briefly. If this is the case you will have to clean out the bowl and gas supply lines.
1- oil type: when you buy it...tell them u want small generator oil...its all the same.
2- start up:turn the red button (on and off button) on(usually UP).
then i prefer choking the engine.
(make sure the feul knob is open)
then pull the string ...and when it starts runnin undo the choking immediaetly.
3- shut down:simply turn the red button off (usually DOWN)..it might keeps shaking...if so...then choke it again.
i hope i helped...send me an email for more details
Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
