Pool & Spa Logo
A
Anonymous Posted on Dec 23, 2010
I turn the heater....it displays A04..and then it shuts off.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Dec 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
13111
Points
25
The problem is within the control board. I have been fixing that problem on the comfort zone heaters for a long time now. You can contact me at [email protected]. The unit can be repaired!
We Fix Ugly Pools
Level 1:
Guru:
  • Contributor 46 Answers
  • Posted on Dec 23, 2010
We Fix Ugly Pools
Contributor
Level 1:
Guru:
Answers
46
Questions
0
Helped
40294
Points
94
Comfort Zone heaters do not have a display board, they only had thermostat knobs.
Is it possible that you have a different model of heater?
  • Randy Lee Apr 07, 2011
    This web site suxs azz!!!!
3answers
How do I fix an A04 display code?
It either has a short in the wiring or may need a new PCB
4helpful
2answers
Ao4 error code
It is either a bad pcb board or you may have a short in the wiring.
1helpful
What is code A04 and how to fix it?
AO4 is a PCB Board used for some of the Comfort Zone heaters distributed by Earth Wise. Try using the up, down and enter for a reset of the unit. If this does not work unplug and try again.
What is code A04
Try pushing up, down and enter at the same time. If that does not work unplug and try again this should reset if the PCB is good.
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 • Dishwashers
Patton POH2520-U heater not working
I have a RD125T heater. At first it would run for a while and shut down. Turn it off and back on it would do the same. Now when it is turned on it acts as if the switch was being turn off and on. Sometimes the heater will fire for a second then shuts down. Most of the time it just shuts down, Forest
2answers
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Top Comfort Zone Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Comfort Zone Pool and Spa Expert? Answer questions, earn points and help others
