Kenmore Elite 45986 Front Load Washer Logo
Posted on Jul 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite HE 3t washer
I put clothes in the washer, soap, downey, turned it on. It started to run waterm stopped, then beeped. It was showing the F32 code. What is wrong?
  • Anonymous Mar 23, 2014
    Washer stopped working f32code
Anonymous
Level 3:
  • Master 413 Answers
  • Posted on Jul 04, 2008
Anonymous
Master
Level 3:
Answers
413
Questions
0
Helped
209731
Points
1203
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
1helpful
My washer stopped midwash. It is beeping and shows 'f' 'h' on the display
Them HE washer machine only use 1 gal of water to wash them clothes. You go puttin in over a teaspoon of HE in there and that washer gonna go into a tailspin I garontee. You probably gonna need to remove that bottom service panel and clean them pump out. That tech sheet will be up in there some6faee41.jpgwhere and that will give an indication of your fault. But clogged filtersf966917.jpg and too much soap is what kills these puppys. Yup operator error. OOpz.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My Kenmore Elite 3t is banging in the spin cycle and the plastic ring behind the rubber boot is shredding. Any suggestions?
are you using a gel soap if not that may be your problem powder soaps cannot be used in front load machines it damagege the bearings in the back of the tub
2answers
A technician once told me to run my Kenmore Elite 3t ( without clothing ) with some bleach to clean the machine on the inside. I do not have a "clean machine" cycle. However I don't remember how much...
Hello , pour the bleach into where the soap would go [about 2 cups], then fill your softner and bleach containers up as well , run a normal wash with an extra rinse , the bleach will not hurt it so the more the better but to a certain point. this should fix alot of the noticible mildew but to get it all use a brush and scrub with bleach.
Phil
2answers
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Kenmore elite washer smells
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap.
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Alexander
vince
