RCA G36705 36" TV Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
Electro Med Services
Level 3:
  • RCA Master 6,694 Answers
  • Posted on Dec 21, 2010
RCA Master
Level 3:
Answers
6694
Questions
Helped
1872756
Points
21433
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
I plug my HP 2000 notebook into living room Vizio TV with HDMI cable, and no problems, the Vizio becomes the PC monitor. I plug into the bedroom TV (RCA) with same HDMI cable, and I get an UNSUPPORTED...
It's a resolution issue before you connect to your rca tv drop your resolution down on your computer and see if you can get a signal. When you connect the hdmi cable it should automatically adjust the resolution but sometimes it don't.
Thanks for your question sure hope it helps if not don't be afraid to ask for more help.
How can i connect my vga dell laptop inspiron to a rca sanyo old model tv
claytonward,
You need a converter to connect. At the links below are some resolutions that I found doing a google search.
http://www.newegg.com/Product/Product.as...
That would convert the VGA output to RCA input... then you just need a 3.5mm to RCA left/right audio cable...
http://www.amazon.com/Belkin-Audio-Cable...
Like that one... to connect the headphone jack to the audio inputs on your TV.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
If my television is 780p how do i achieve this quality?
You do not adjust the resolution at the TV, the TV will display what ever the source resolution is as long as it is not higher than the TV can handle. Source determines the resolution, just like the computer monitor, which is controlled by the computer.
1helpful
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
2answers
Laptop to tv
hi there its not possible to conect a hdmi cable from your laptop to your tv its somthing iv never herd of but if your laptop has an s video out put theres a sure bet that you will be able to send this to the tv using the graphic softwear that cam with your laptop hope this helps a little thanks
PC via DVI to D52W20
I'm using a component dongle from an ATI x800. Never have had a problem. My resolution is 1664x936. I noticed that this RCA auto formats the screen size with the DVI-D or component, so you'll have to make the adjustments via your video card. Windows display properties might not let you select that resolution, so hopfully your video card software will allow you to pick a resolution. It would not let me use any kind of 720p resolution only 1080i settings would work.
RCA TV RCA D61W20, Weird Problem
did you adjust the set in both modes 1080 and 480? They both need to be done seperately.
Audiovox model VOD715
Also program it as a DVD. That seems to work. I had the same issue.
Covergence problem
press and hold menu then push power then volume.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
