SOURCE: i have a mitsubishi wd-62725.
Sounds like the classic bad capacitor problem on the DM pwb. You can get the V26 DM pwb repair kit at the following link which will usually repair the issue. Kit contains replacement capacitors and CD with chassis dissasembly and explains which capacitors need replacement.
http://servicemanuals.vstore.ca/
SOURCE: blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
SOURCE: mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
SOURCE: Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
SOURCE: my mitsubishi wd-62528 has a constant rapid green
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
