20 Most Recent Mitsubishi WD-57731 57" Projection HDTV Questions & Answers
Tv was turning itself off now it wont come on at all
Replace lamp. Clean (vacuum thoroughly) cooling fans. Make sure they are vacuumed and turn easily. Lubricate them with a tiny drop of Z-Max on each bearing. If the problem is in the lamp power supply or main control board, replace them. Regards.
1/5/2016 4:12:57 PM • Mitsubishi... • Answered on Jan 05, 2016
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual: Blinking yellow= Lamp cover is open. It could be something else! www.aaatvservice.com
8/15/2014 11:43:40 PM • Mitsubishi... • Answered on Aug 15, 2014
0answers
0answers
0answers
Reset password
Be the first to answer 2/20/2014 6:00:31 AM • Mitsubishi... • Posted on Feb 20, 2014Be the first to answer
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
12/19/2013 8:54:43 PM • Mitsubishi... • Answered on Dec 19, 2013
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
10/15/2012 3:54:57 PM • Mitsubishi... • Answered on Oct 15, 2012
3answers
Wd57731 57 inch
There is no way to check it unfortunatly.
10/11/2012 9:11:03 AM • Mitsubishi... • Answered on Oct 11, 2012
Bulb burned out on my TV
www.TvRepairKits.com has the bulbs for around that price and you can use the code "freeship" to get free shipping
10/9/2012 2:24:33 AM • Mitsubishi... • Answered on Oct 09, 2012
Mitsubishi 57731 picture on for about 1 minute (looks normal) then shutsdown, solid red Lamp LED on
check the fan if it is working.
10/5/2012 10:20:18 AM • Mitsubishi... • Answered on Oct 05, 2012
2answers
I have a Mitsubishi WD-57731 DLP TV. The TV
My mitsu wd-y577 television has little white dots all across the screen and it gets worst everyday the dots cover 40% of the tv help
12/12/2011 8:45:07 PM • Mitsubishi... • Answered on Dec 12, 2011
Several white specs appearing at random and increasing in quantity. Whats up?
White does suggest (dots) a damaged or bad optical light engine.
11/22/2011 12:54:56 AM • Mitsubishi... • Answered on Nov 22, 2011
My wd-57731 will not trun
if you have change the power capacitor which are the major common problem, Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement. Hope this will help out in solving the problem...
8/20/2011 10:10:10 PM • Mitsubishi... • Answered on Aug 20, 2011
2answers
Hole in screen need new
alldecked506,
Go to http://www.encompass.com to get the part and use my tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen for instructions on how to replace the screen.
Thanks for using FixYa and for the great rating.
hardrocko
7/16/2011 3:49:35 PM • Mitsubishi... • Answered on Jul 16, 2011
Some times my cable HD signal gets blue screen
Sorry to say that most HDMI issues are that of the scource and not the TV. You can check with Mitsubishi to verify that you have the latest version of software for your TV, but that is no guarantee that it will fix anything. If you have tried other devices on the HDMI port without any issues then you definatley point out that the cable box is at fault. Maybe the cable company should swap out the box..
4/27/2011 3:10:37 PM • Mitsubishi... • Answered on Apr 27, 2011
Check airflow sensor turn tv off
Your TV needs the modified temp sensor installed by Mits authorized service center. It's covered under extended warranty for 3 years after date of purchase. Repair takes about 20 minutes and not too expensive if you're out of warranty period. Part #299P313010A
Bill W
integrityhomeworx.com
3/9/2011 3:34:24 PM • Mitsubishi... • Answered on Mar 09, 2011
Mitsubishi WD-57731 57" Projection HDTV Logo
84 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
blinking yellow light mitsubishi wd
  • Televison & Video
