Sony Handycam CCD-TRV108 Camcorder Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im charging the battery, but when i put the battery on the camera nothing happens, no lights come on, the battery is charging but i was wondering if the only way the camera will come on is if the battery is fully charged. This camera has not been used in more than 4 years.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Dec 20, 2010
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470439
Points
19564
Your battery is wear down is wear down and need the replacement
I put in my battery after charging and the camera opened but it will not take pictures. The lens will note retract. when I press the on button the green light comes on but the camera buzzes and nothing...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
3answers
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
2helpful
3answers
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
1helpful
2answers
Pentax
You can charge the battery using the USB cable. The camera has a built-in recgargeable Li-ion battery, but the AC charger is "optional" ... go figure...
Nice camera, btw...
I'm not aware of any indicator light on the camera. The optional external charger has a red lighht that turns amber, then green.
It wont charge when i plug it in or will any lights come on nothing happens at all
The S210 is a camera, not a battery charger. In order to charge the battery, remove it from the camera and insert it into the supplied battery charger.
1helpful
BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
2answers
Charging battery
I have the same camera.
But when your camera is flashing the green light, that means it's transferring pics.
If the light is just green on the camera, that means that it's charging i think.
But i don't know how to tell when my camera is through charging is my problem.
Nov 23, 2007 • Cameras
2answers
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
