GPS Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can we charge the Garmin in the house and how long does it take to charge in the car ours is the 1350 model
Anonymous
Level 3:
  • Master 1,514 Answers
  • Posted on Dec 19, 2010
Anonymous
Master
Level 3:
Answers
1514
Questions
Helped
332235
Points
3516
You can buy a mains charger from any shop that sells garmin satnavs to charge it in the house. Or you can charge it by connecting it to your computer with the mini USB lead. Charging with a computer takes about 8 hours while charging with a car charger or a mains charger takes about 4 hours.
tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Hard Reset
on May 15, 2010 • GPS
My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
tip
I hope that helps.
tip
I hope that helps.
tip
I hope that helps.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
