Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
SOURCE: olympus stylus 790 sw:windows vista does not recognise the devise?
there is none, olympus shld bl00dy fix the problem
SOURCE: cannot print pictures with dates
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
SOURCE: Need manual for Olympus Stylus 850 sw camera
you can download the manual here http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/STYLUS%20850%20SW-_F Please note that the user guide is in French
SOURCE: Dropped my Olympus Stylus 1050 SW... now it wont turn on!
Get a new camera something broke on the inside of this one the term shock proof does not cover dropping the camera and the term waterproof does not cover submersion in water these terms must be taken very lightly shockproof means a good shaking won't bother the camera and waterproof means a drop or two of rain wont bother the camera. GOOD LUCK
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
